Star Wars keeps blowing F3 fuse
oktobernv
Henderson, Nevada
Fuse is a 20A 32V
Changed it twice, blows as soon as game is powered up
Looking for advice on where to begin digging for the problem.
Thanks in advance
Rob
First off, it should be a 25A fuse. It was field modded for all Atari games.
Next, pull the power brick and test your BR.
Fuse is a 20A 32V
Thanks in advance
Rob
Thanks for the tips guys
I will replace the fuse with the 25A and test the BR
Will report back
I GREATLY appreciate the help
Rob
Dokert you NAILED IT!!
Awesome work from afar man.....awesome.
Pulled out the SW power brick this AM
Tested the bridge rectifier
sure enough - it was bad....
Pulled out the power brick from Tempest (since it's down for other reasons at the moment)
tested it's BR - tested good
Swapped the good BR into my SW power supply
Powers right up
Star Wars is back.....again!!
Thanks for the help yesterday guys.....
Rob
