Star Wars horizontal jumps
Altan
Georgia
Turned on my Star Wars and the image was jumping in size but only horizontally.
Thought it might be some pot issue. I took a look and found this on the deflection board. See r24 and r25
Is this after market?
After spinning it back and forth a few times, the problem seems to have gone away.
The width pots were aftermarket, they are all like that, on most beige and green boards (I have 1 blue board with it too)
It's a good idea to replace the pot (10K ohm), as the moving of the pot is probably only a temporary fix :)
Is it a standard 3 leg pot? I'm not able to check right away...
Do these from Bob look right / appropriate?
I know it's not for the same resistor jumps...
I always replace them when working on an Amplifone deflection board.
Yes those are the correct ones from Bob.
Here's a video I made a long time ago about the effects this has:
