Star Wars graphic shakes
Mr Do
Donor 6 years: 2012-2013, 2015-2016, 2019, 2025
Basking Ridge, New Jersey
I know it is the HV board.
On the HV board I just checked my C1 & C2 and see they are rated 1000uf.
I saw it should be 50v
Could that be why my graphics shake?
The rebuild kits for Amplifones are typically 1000uf 50V where as the stock ones were IIRC 450uf 50v. The ones installed are fine. Did you ever check the actual HV output? Should be 19.5Kv. I could see shaking and so forth if this is incorrectly adjusted. Also a posssibility that the wiring harness is the culprit (tho not likely).
