GameyMcGame
Not sure if this is a monitor issue or a board adjustment.
As an example...In ESB, the picture of Darth vaders helmet...His mouth (which is made up of about 7 vertical lines). All of those lines seem 'shifted' to the right so they dont line up perfectly to where the mouth is supposed to be.
I have the WG monitor but am not sure if I should mess with the rings on the monitor neck or if I should try adjusting on the board itsself...
