There's a line coming out of the middle of the death star when I blow it up points to the top right corner of the screen on my 25" amp. Is this just a normal burn it or should I adjust something. Everything else is flawless fyi
For clarity, you said "Burn In". Burn In is something you see when the monitor is off.
I'm going to reply to this post under the assumption you saying burn in did not apply here.
The brightness setting on the Monitor may be too high and you're seeing some lines that with the brightness turned down, you wouldn't normally see.
The Death Star explosion is the brightest the monitor goes in this game. So much so that if you run one of the tests within the game (stepping the game through it's program) it warns not to use this test during the Death Star explosion as it may cause burn in damage to the monitor because of the brightness of the explosion.
Turn the brightness down with the "Screen" knob on the Flyback. Not a lot, just enough to make the line in question disappear.
There is a metal box on the left hand side of the monitor that has a white plastic piece with two knobs. The bottom one is brightness. Top one is focus.
