ls1chris
recently resurrected a dead avg board , although it still has something messed up with it .
the bottom 1-1/2 inch is wiggly and messed up. please see photo's .
it is something common in the out put as when its in the grid screen and i change between the colors it shows the same systems. it also has weird systems in the red raster screen but i will have to take photos for that.
the 4-10 at 1N was burned up as the original problem.
1- not main CPU related, the problem does not show with two other working AVG boards.
2- not interconnect related , the problem persists between with any of the 3 interconnects i have.
3- no burn on any of the finger board connectors , they have been cleaned with a fiberglass pen , and the physical cond of this board is like new, i suspect it had very little use prior to failing and went to the shelf early on.
4- all V's and sense and present and proper.
unsure where to look and what to test now.
would love some input and suggestions what to test and where to look.
chris.
chris.
