Star wars Arcade Marquee reinstall?
jonathan1138
Whitestone, New York
Hi. I just redecal'd the entire cab (came out nicely).
Putting the Marquee back on - just want to make sure i am assembling this correctly. Feels like something is off.
I understand i drop the wood frame / marquee section on the top - than screw it down. Where does this black metal bracket go (three screws it takes) - does that go under the Marquee wood frame (screw into the wood portion / into the metal) (the holes line up). Something feels off if i do that AND when i was dissasembling i made a mental note that the assembly was odd.
Thanks for the help....
I am hoping that I am understanding what you are asking here. The pictures below are of a Xevious Marquee which is similar to the Star Wars. The metal piece at the bottom is attached to the frame with the three screws.
attachment.php
attachment.php
You then apply the marquee by hooking that bracket on the underside (I think there is a channel) of the marquee area on the cabinet and then screwing the assembly down on the top.
ArcadeMaze!
Thanks so much. I was thinking the metal bracket goes to the top lip (under it) - but that seemed to serve no purpose. I will attach to the bottom and hook it to the front. Thanks again.
