omegaman
Could be the Wintron windings have shorted, seems like you have checked everything else, did you pull c8 and check it for short?
I had one where C8 was the problem and kept blowing the regulator before I figured out what was the problem but you say you checked it. I have never seen the Red "mystery can" go bad, but if I remember right, some get damaged from the heat off the 50 ohm resistor and can cause problems. Might want to go back and read that in the FAQ.
Edit :replace the pots on the HV board too while you are at it, Bob sells them.
Ok C8 is not shorted so the Win must be Dead
So I guess I'll palce an order with Bob Roberts and try a new flyback. I think he sells the one's from Cinelabs. I also need a few other parts but I have most of it already. Even gonna put new caps in. They have low hours on them but I did install them 10 years ago. We'll see what happens.![]()
Dezbaz, did you verify that 12VAC with a scope? you could always lower the winding count to drop the voltage if it's too high.
Well I un soldered C8 and checked it again and it wasn't shorted. With my OHM meter it gave me no reading at all like it's open. Is this correct? I would have ordered one from Bob but I did not see one. I have read the FAQ forward and backward and almost know it by heart. Their's no heat damage to MC1 or T1. Also I have said it before I am getting a pulse on pin 3 of the 555 timer. Checked it with my logic probe.
I have not as yet.
My point is: Some HV Transformers are going to blow up heaters. Straight out of the box they are giving 12.2VAC
I was warning people who bought Bob R Flybacks to check theirs, before the tube is rendered useless
Mouser sells a cap that works as a replacement. I am headed out the door to work but can get it for you later if you want one.
Wile I was at it I did some searching and found someone that was looking for a replacement for the diode at CR3. Mine tests good but I figured I would order a few wile I was placing an order and if they were wrong maybe I could use them for something later. Here's the number , what do you think? Part number 526-NTE558 The NTE558 is a general purpose silicon rectifier in a DO41 type case designed for low high voltage
fast recovery applications.
I would hope if their was a problem with this fly back someone would have found it before now. Yes the voltage could drop when under a load. I would hate to burn up my tube as they are not cheap and hard to find. I am sure if it was putting out to much voltage the tube neck would be very bright. I wonder how many of these have been installed and if any have had a problem?
Hey Sam,
At one point, I was convinced that I had no HV because I couldn't hear much sizzle on power on / off. It turned out that the 6.3VAC was absent from the neck. Once I tapped in from the coin door, I saw a picture for the first time. My transformer was not outputting the 6.3, so no matter how well everything else was done, I'd have never seen anything. My transformer was band new (Cinelabs), and it still wouldn't do the 6.3. In fact, two of them burned up at the 6.3, but that's a story for another thread.
I'd tap into those AC wires to make sure you've got glow at the neck. No matter what else you do first, you won't see anything on screen if you don't. You can always make this mod temporary and seal the wires back up if you get the Wintron issue worked out. Oh, and use a DMM to read the WHT HTR and brown solder points on the HV board while powered on. If you don't see the 6.3 there, it ain't got it.
Good luck!
