SeaWolf
my game shows color dots in all the grafix places
Montor is fine in another machine
Power suplly working and correct voltages
Have you tested other boardsets in that same cabinet or those boards in another cabinet?my game shows color dots in all the grafix places
my money is on the XY timing boards...
mh
Scott C.
mh
Thats the kind of info that should be shared at the begining of a thread. LOL Yes you should either replace the broken pins or find a cable. It will be easier to replace the pins though.
when I play the game I notice the score and the ships on the radar screen are doubled. Sometimes I get fooled and think there are two ships I have to fight, when its only one. Some ships on the radar show up fine, but some will be two images, slightly overlapped. And the score is the same, one number slightly overlapes the other.
This may be easy.
Are the doubled images the same color, or different.
If they're different colors, then your convergence is off. I think the score and those pink triangles for the klingons are made from the red and blue traces.
You can go through and perform a color setup for the monitor, but Star Trek doesn't have good test screens for that.
There is a trick with either the service or the reset switch where you can get the screen to freeze. I recall using the screen with the white STAR TREK logo to aid in converging the beams on the screen.
The convergence in that upper left corner is more important to gameplay than having it dead-on in the center of the screen.
Good luck-
Kerry
I found this video, is this what I need to do?
And where do I buy those strips?
At the strip joint of course.... Wells Gardner sells them, but they have a 75.00 minimum order...
mh
