Star Trek TNG
ag21197
California
Hello all. Maybe some one can offer some advise. The 'Neutral Zone' stationary yellow target with the Romulain, Ferengie, and Cardassian decal: It doesn't seem to responsive to the ball. When it prompts you to hit the target to start the above mentioned games, it won't start after being struck with the ball. I am able to get to go with my hand by pressing the bottom of the large plastic target with the decal and the pushing on the center part of the metal just below it at the same time simulating a ball strike. So it is functional.
Any thoughts or suggestions.
look for discolored switch contacts... and make sure the ball can actually cause contacts to close.
Go into switch edge test, push it with you finger. If it doesn't work, turn the game off. Stick a piece of paper between the point blades and push them together and pull out the paper to clean them. Look to see if they make contact when push or if they are bent out of adjustment. Then check for broken wires or diode.
Then try again in switch test.
That would help most situations. If not, that switch is part of your switch matrix and you could have a broken wire at another switch using the same color wires killing it.
LTG :)
