spanks_4
Working on a Williams SG for a friend that had the boards repaired by some guy. Well the guy sent a computer type power supply back to use and labeled most of the connectors to go to different boards. The only things I can't get to work are the control panel and the coin door.
History: Someone hacked in a switching power supply and did a number on the wiring.
Q: What color wires are the CP and coin door ground wires? Also on the CPU board their is a 3 slot connector *very top left side that has two pins* that is missing. Anyone know what this connector is supposed to be for?
