star castle wierd graphicss
mr.fixit
arnold, Missouri
so got my star castle hv issue fixed , replaced a cap in the quadrupler circuit a .036 at 400 volts with a .03 at 630 . and i get this any clues. a bad dac, or wrong value part causing this.
is the HV on or off the deflection board? I just worked on a Ripoff monitor with the HV on the deflection board that did the same thing. problem was broken wire on the HV transformer.
mh
star castle fix
ok, i fixed it broken wire , except inside the quadrupeler module :( . so i built my own 90v power supply from a 2 110 wall warts a 7v and 9 connected them a bridge rectifier and cap and bingo she runs like a top.
