SSB 2009 stuck on 5.6% file check
Milton187
Donor 3 years: 2016, 2019, 2021
Wahpeton, North Dakota
Ok, thanks to jimmyfloyd I am off the purple screen and now stuck on file check screen at 5.6%.
Any ideas as to what causes this?
Milton
I made a new hard drive image and installed it.
Now stuck on 44.4% Dynamic file system check.
Any ideas?
Milton
What size/brand is the hard drive?
How long are you giving it to do the hardware check?
What program are you using to make the hard drive?
Iam using a 250 gb hd. Seagate I think. I'm using a HD image I received from a website that should be the right image for my version.
I have made it to 43% after rebuilding the image. Using a computer monitor as you cannot read the ssb monitor during boot. Let it run overnight. No go.
Milton
It's a WD drive. 250 GB.
IF I use the image I received from the web, It says something about rolling back the update.
Then it reboots. Then it gets stuck at around 39.3% checking Dynamic file system.
My guess is I have the wrong Image?
My HD says SSB Club V1.00.07
4-10-07 Hitachi Deskstar
BUT i have a #19 CID.
Anyone make sense of this?
Milton
How big is the image? The 1301 is around 22gb, I would have to look at my images to confirm this.
