Spyhunter Button Problem
Boo32
Richmond, Virginia
I have a spyhunter with a sticky button for the smokescreen. The button seems to be stuck about halfway down as though the spring has failed or it is just gummed up. As a result, the smokescreen deploys as soon as you leave the weapons van. Anyone have tips on rebuilding or unsticking this button?
Sticky Button
Hey.. I believe there's a small micro switch inside the steering wheel. You'll have to take the steering wheel apart to open it up and change that switch. While you're in there, if there's anything gumming it up, you may want to clean it up with WD-40 and wipe it clean.
