72Demon
Hello, I am posting my next Spy Hunter problem now in this section. Previously, it was a monitor issue, now that I have a somewhat working monitor I found that I can not control the Spy Hunter car. It will only go right and drive in the trees. You can not turn left, the car itself does not turn left either, you can see it turn right when you turn the wheel in that direction. I had a similar issue with my Tron that the Tron control would not go left. I found a loose connection in the main Tron pcb terminal. The Tron was a little easier to troubleshoot since it was not too difficult to follow the lead for going left. On Spy Hunter it is a steering wheel with many wires. Not sure where to look or what to check.
This is a nice looking cabinet I bought not working along with a ruff shape, but mostly complete second cabinet. I purchased a working PCB from CDJump and have it installed in this good cabinet. Could this just be a calibration issue? When I had this same PCB installed in the ruff cabinet it could steer fine. So that is why I did not think it was a calibration issue. The control panel on the ruff cab has stuck thumb buttons and is not as nice, so I did not want to just swap out the control panels.
Here are some blurry pictures of me driving in the trees, did not realize you could go so far in the trees and bushes in Spy Hunter!
Any suggestions on where to check next?
