Museum of the Game® & International Arcade Museum® Forums
Hey, I just picked up a Spy Hunter that seems to play great but the weapon lights aren't working (including button on wheel). I found an older thread which I tried to follow but so far no luck. First I checked voltages at the bulbs and not getting anything there. So my guess is it could be the lamp driver. From what I understand J2 pins 5,6 should read 12V which go to the lights. Stupid question, but I want to make sure I'm doing my measurements the correct way. I put my black lead on ground (pin 11) and red lead on pin 5, then pin 6. Is this correct? I barely getting anything when I do this. Also, is there test points on the lamp driver board so I can check to see if the 12V is even getting there?
Thanks!!
