What should I use to replace a volume pot on my Spy Hunter? The game sounds volume is low even with the pot cranked all the way up and I'd like to have it working all the way by Saturday for my Halloween party. Thanks!
Take a multimeter and measure the resistance between the wires going to the pot when it's turned all the way down, and all the way up, and you can tell if it's working right. If you measure the two outside ones, it should tell you what size resistance pot it is, too... so you can get the right one.
Is the music volume OK, but the sound effects are too low? If the music pot works good and the sound effects pot does not, you could swap them really easily to troubleshoot.
