Ok..So the spy hunter has been acting up lately. When it boots it will just go to a garbled screen, after a while the game will load, but will reset quickly..I checked the +5 on the power suuply and it was a little low. I got it to about 5.05 and then checked the voltage across the board and it was about 3.6..I got the +5 on the PS up as far as it would go..5.44 and was still only getting about 4.04 across the board, so I'm looking at a pretty consistant drop of about 1.4 from the PS to the boards.. So where to go from here? I figure there is no need to rebuild the power supply as it can get up to 5.4 and the issue seems to be in the boards. Is this a simple case of replacing all the cables and connectors? Any thoughts?
I don't know if this is relevant or not, but when I tried turning it on this morning, I couldn't get the game to boot at all...wouldn't get any neck glow either..I pulled the PS and the fuse was busted, after replacing it, it would continue to give me the same issues it has been.
