Spy Hunter Steering Wheel supposed to center itself
zutton1
Donor 2011, 2018
New York
Ok I replaced the steering wheel on spy hunter...seems tight...only thing is not sure if it's too tight...Is the wheel supposed to go back to center when you pull it to one side and let go? mine just stays in the same position...also I had to adjust the pot calibration in test mode not set at recommended but set a little to the right...Thanks for any Help!
on my project machine, one of the springs cut through the large flat plate it attaches to, so it always returns to the other side. gotta find a welder with good aim to get it repaired one of these days.
Ok...anyone sell these springs or know where to get them...should any part of the steering shaft be lubricated? When I took the old one off looked like it had grease on it. Thanks!
