Spy Hunter steering grommets
Shavenyak
Donor 2023
Sarasota, Florida
Any ideas on where to find these? The steering springs go into these, which go into the steel plate. I guess the grommets protect the steel from wearing.
Ace has them in their bins in the hardwar isle.
Are the grommets plastic or metal?
I looked for these a while back and couldn't find them.
OK, I remember now.
The problem with them is that the springs tear through them and just go to work on the metal plate -- and eventually tear through those too. Almost every SH I've seen has this issue.
I was looking unsuccessfully for metal ones back when I did this.
OK, I remember now.
Yep. That's where we're at. It's getting too close for comfort. I'll have to check out Ace.
If you find any metal ones please let me know. :)
In the meantime you can probably rotate your plastic ones to put the pressure on a different spot.
mine were completely missing, and the hole completely wore through. I just drilled a small hole beside the original one that i hooked new springs to (on both sides).
Mine too. And those were ripped through as well.
It really seems to be a cycle of self-destruction. Wish I could find some metal grommets that would hold up and distribute the force of the springs over a wider area.
I just went and looked at my SH - with very little effort (but opening the hole up just s smidge)
you could use this setup -
1/8" npt nipples
and
1/8" npt brass nuts
Cut a short piece of the nipple, with a nut on top and bottom and you should be good to go.
I got these at Ace Hardware. They aren't perfect, but they do the trick, and they're much better than nothing. They're $.30 each.
If anyone wants some, let me know. I don't mind getting more and mailing them off. I won't bother asking for payment, unless I get a bunch of orders and it starts running into money.
Did you get a part number, by chance?
