Ok, so my Spy Hunter had a power supply issue and just needed general maintenance so I decided to tear it completely down, clean, maintain, cap, etc. I switched over to the MCR switching power supply adapter and that took care of my power supply issue but now I have an issue where my car will just suddenly pull to the right or left and crash. Other times it will just for an instant pull to the left or right but then get back to normal before crashing. It seems to be related to the gas pedal because in 'player input' in the test menu the gas pedal readings also affect the steering wheel readings... but usually only when the steering wheel is in a certain position.
Hard to explain so I can make a video but in a nutshell the gas pedal is effecting the steering at times. Suggestions/advice?
Thanks in advance!
Thanks in advance!
