Spy Hunter pin help
GameRoomKid
Donor 2012
17021, Pennsylvania
My cousin and I moved the Spy Hunter pin around and now the game sound isn't working. It worked perfect before we moved it. I took the game apart, tried going over the manual, stared at the machine for about 10 minutes, then put it back together without any success because frankly I have no clue where to begin looking. Any suggestions?
Try reseating the connectors between the sound board and CPU board. Take a look at the connectors from the side that touches the board and look for broken connector pins.
Try checking the connections to the speaker in the body of the cab... If they are loose like mine they fall off if you just look at them the wrong way.
- Mike
