Spy Hunter owners: +5v setting?
ifkz
Texas
I am having to set my Spy Hunter's +5v at upwards of 5.18v to avoid resetting. This higher than all of my other boards, and worries me a little. Could it be old caps on the boardset that need to be replaced or is this just thirsty? What setting do my fellow KLOV Spy Hunter owners use for their +5V line?
I agree....5.18 isn't a big deal. One question; is the reading at the motherboard or the power supply board? Just because the power supply is set at 5.18VDC, doesn't mean the motherboard is getting the 5.18VDC.
Edward
5.00 - 5.05v on one of the eproms on the ssio. Even measuring at the power connector on the board will show some difference when you check it versus the readings on the eproms.
I've seen quite a few MCR games with the input power connector burnt up....might want to flow some fresh solder on those header pins.
Edward
