72Demon
I have two upright Spy Hunters I purchased non-working. Originally one had a PCB issue which showed a K and R screen when powered up, the other SH is in ruff shape and had no PCB. I purchased a working PCB from CDJump here on KLOV. Now it appears to be working except I have alot of static on the screen and noise in the audio. I am not sure if I messed up a connection somewhere or if something is going on with the monitor now. I checked all the connections I messed with and can not find anything. I put the working PCB in the other SH and got a picture that looks fine, so not a PCB issue. Prior to me, changing out the PCB, I did swap around power supplies and the other boards to test them. So there is a good chance I caused this issue. I do not recall ever messing with the monitor when I tested the other boards, except for where it plugs into the PCB.
When it had the original non-working PCB, it did not have the video problem or the audio noise. I hope someone on KLOV has seen this problem before and can tell me what is causing it. The monitor is a Bestech WHD 94V-0, chasis with a Panasonic Tube. I tried moving around the syncs but it did not help. Thank you for anyone who can help.
