FlashShift
- Joined
- Jun 18, 2025
- Messages
- 171
- Reaction score
- 199
The final prototypes finally arrived and I'm populating a small number of these boards to pay for the R&D costs of this and other adapters.
This adapter maps the steering to a joystick or gamepad L/R with an adjustable speed. L/H gear is toggled with a button. Acceleration pedal is emulated with a button+gear for cruising speeds, and a "turbo" mode by pressing up, to get the tail pipe flames. Similar feel to the NES version.
Supports battery save, switches for CHAMMA support for buttons 5-6, weapons indicator LEDs, reset circuit, and support for mixing both effects and music, if you have a Cheap Squeak board. A lot of work went into this so I'm asking $129 for a populated board to cover component costs and R&D plus $12 flat rate priority shipping.
If you'd prefer to build one of these yourself, I'm happy to send you a bare board for $10 plus flat rate priority shipping ($12), DigiKey BOM provided. I also have the CAD for this board in my public repo if you'd like to learn how it works.
This JAMMA adapter does not come with the Molex connectors, you'll have to put that together yourself. Easiest way is a pre-crimped kit from Amazon. A guide is right on the silkscreen. Shouldn't take long at all with a precrimped kit.
Lastly, I have an extra working Spy Hunter PCB stack complete with Cheap Squeak (music) and fully adapted to JAMMA with all connections I'll let go for $850. Can send photos on request.
