I found a picture of the connectors on my Spy Hunter game and looked at what you typed.
I'm not sure if you should be putting ground on the white/yellow or the white/black (which is logic ground). I'd try putting ground on white/black, with your DMM set to 20v DC and your red probe in a red socket first for 5v readings and then an orange socket for 12v readings.
5.8v is too high if that's a real reading. And obviously 12v is almost non-existent so that would be problematic if that's a real reading.
12v is used for lights so if your coin door lights aren't working now that's probably why.
I'm not sure what else SH uses 12v for -- cdjump could probably tell you off the top of his head as he is an MCR god.
