It's not awful yet, but I'm starting to get some sticking when the accelerator is pushed all the way down. Upon inspection, it looks like maybe some of the gear teeth are getting a little bit stuck (only because the sticking is very "clicky").
Has anyone encountered this before and found a good fix? I'm wondering if a little WD-40 will do the trick, but I don't think it's really a rust issue. It seems to be more of a teeth mismatch issue, just not so much that it's visibly obvious. This just popped up in the last couple of days.
Thanks!
Thanks!
