Spy Hunter cockpit-
synonym9
Vienna, Vienna, Austria
I have received a Spy Hunter Cockpit today but it would make sense to share it in two parts to store it.
How easy does it come apart and how?
Does the coindoor-harness got a plug to unplug front and end-section?
Is the rear-section lightweight so I can lift it up the top of the front-section (cartboard and stretchwrapped)?
It comes apart rather easily.. simply unscrew a few bolts on both (lower) sides of the cabinet, near the split. Then unhook a couple of molex connectors, unscrew a ground strap, and the pieces are separate. The rear (seat) area is relatively light compared to the front half containing the monitor, etc., but I would not recommend stacking it on top of the other section, if that is what you are asking. I would store the two pieces separately on the ground..
Thanks to both...the instructions are very usefull.
You talk about the bolts in the red circles?
What the the bolts in the green circles...that ones too?
Yes, unscrew the reds and the greens. Greens hold a trim piece you'll have to remove too. One more thing--you will also have to remove the floor (big sheet metal piece with Spy Hunter logo). I think it may have some small screws around the edges...
