spy hunter channel 1 issues
titanfan
Tennessee
My spy hunter is finally now play as near perfect as it ever has. Just one tiny sound issue on channel 1 pertaining to car crashes and explosion sounds. it makes a terrible loud buzzing sound when those sounds occur. Now the question is where to start.
Does channel 1 sound distorted in test mode? Swap the two AY-3-8910s on the SSIO board with each other and see if the problem changes to different sounds.
sounds the same in test mode as it does in normal play mode. I have swapped the chips and no change.
