I am switching my Blitz 99 to a sportstation. I have installed the vegas board. The joysticks are not working. I read people had this issue before. What is the fix? I have only connected player 3 and player 4 from the harness.
As mentioned ensure your dipswitch settings are correct.
The Vegas boards - player 3 and player 4 are physical header connections on the Vegas board while Player 1 and Player 2 are actually connected via the JAMMA harness (which btw your current harness probably doesn't even have connections for Player 1 and Player2 present) so you'll need to get another harness. The I40 board is not needed so if you don't have it no worries. There is a guy on eBay who sells the NOS Sportstation JAMMA harness. Get ready to do some soldering and possible monitor connection modifications. It's not a slam dunk process.
