Speed Buggy schematics
Tornadoboy
North Attleboro, Massachusetts
Hi everybody,
Got a Speed Buggy boardset coming and I was wondering if anyone knew where I could find the schematics? I've got an abreviated manual in a pdf but that really doesn't have much.
Hi there.
I'm also looking for those schematics. I've got this boardset, I've adapted it to Jamma (even simulating the optical controls), but I cannot make it sound.
Thanks!
I have a manual someone else was kind enough to scan when I had one a few years ago. I don't recall a schematic in it.
As to sound, there is an external amp it uses. I want to say it has some silly number of channels that gets mixed together to come out the 2 speakers in the dedicated upright. Look at the des on klov. The board is the same as used in some over the top multi monitor multi sound channel cockpit. The volume knobs on the top board are like preamp levels. They effect the level of the various channels to the amp. The amp had a volume pot for the final, mixed, amplified sound.
I'm using an external amp too. But nothing gets out the four pre-amp stages. I've also noticed that the CPU board needs +12 VDC, and has a pot marked as VR1. Is this a volume pot? Is also the CPU board involved in the sound?
Thanks for your help.
EDIT: Got here, but the file isn't available for downloading. tta583, do you still have the copy of the manual? Thaks!
