Spaeth Dragons Lair Score board - direct fit?
jonathan1138
Whitestone, New York
Hi all. I bought a Spaeth DL scoreboard from a member here, who assured me it was a direct replacement for the original DL scoreboard - pins and all.
That person was initially helpful when i got the board and realized the pins do NOT line up. Unfortunately i havent heard back from him and still kind of at a loss.
I know i can ask M.S directly, but thought i'd ask here first - does anyone have experience with putting in a Spaeth DL scoreboard to an existing DL cab? Does the wiring change (the pin connector?). If it does need modification is there a resource out there that would explain how?
Thanks again.
I might need to take pics on this one. I think the (new) board is Dead.
I have a working DL board with an annoying hum. So i order this Speath board. I mount, and plug it in. Pins line up, its a little tight, but they line up.
Board no worky. Email seller, he suggests that theres a different way to plug it in?
Verify that your DL board is in fact working as you think it is.
Verify that the person did not sell you a dead replacement display.
Verify that the ribbon cable is good.
Sounds to me like you have it hooked in properly and one of the three is not good.
Thanks Chad. My original DL board works perfectly. The replacement board just "hums" and doesnt display anything.
Back to the seller.....
