space shuttle question
Musleh
Lafayette, Indiana
I haven't ever worked on a pinball machine. This unit lights up on the board, but doesn't recognize anything else. Is there a fuse I should look for.
Also dumbass question, how do you raise the playing board?
Thanks Burt, any takers on first fuse/relay to look at?
Not the best person to answer your questions, but can give some clues.
You will want to grab the manual if you do not have a physical copy.
It is a system 9 machine so this is the pinrepair page you need.
I would pull the fuses out behind the back glass and make sure they are all good with a DMM.
Then move on to checking what the LED flashes are telling you.
Can you clarify what you mean by it doesn't recognize anything else? Do you get anything from the game besides the general illumination? Do you mean you went into switch test mode and it doesn't recognize any of the switches?
