Tantora
I'm thrilled to now own an SI, Midway ver. However, I will be more thrilled when it's back up and running. It was working last week when I picked up. After 10 minutes of play, it started showing gibberish. Shut it down, and it got worse. Took a break, the next morning it worked fine (back to normal) for about 10 more minutes, then went completely blank. Monitor shows a neckglow and projects a blank screen. Power supply has the appropriate voltage readings. I believe the only other remaining thing to troubleshoot is the motherboard. Cap kit? Pics of the gibberish before it went blank below.
