I'll check the voltage tonight. As far as brightness goes it looks bright enough, I can just see it strobing. When I got it, the filter cap was missing. I found it in the bottom of the cabinet. The legs weren't broken, looks like it just fell out. Of course the wire ties were missing. Could have been the previous Op's fix. It could just be bad solder joints, because I also found a resister that had one leg pulled loose from the board. It wasn't broken either. It just looks like the solder let go.
Jeff
