Bit Fail Error - Fixed
I just wanted to post to thank those that offered advice and suggestions in this thread, as it helped me get my Space Invaders Deluxe fixed.
I bought a Midway SI Deluxe in a cocktail cabinet from a guy about a month ago for $50. He said it wasn't working- the monitor had 'gone out' and the power cord had been frayed, so he cut it off so that his kids wouldn't try plugging it in and get fried.
After I put a new cord on, I plugged it in and the control panel lights and fan came on. I could also see neck glow on the monitor. After googling around a bit, I took the boards out, cleaned all of the edge connectors and pressed down on socketed chips to hopefully reseat them. That worked, and the machine seemed to be working.
The only problem was that about 25% of the time after I turned the machine on, there would be lines under all of the aliens which interfered with gameplay, and flying saucer sound effect would play constantly.
In the hopes that it might help someone else diagnose their problem, I'm attaching photos of the lines and a link to a video:
http://youtu.be/m2xCpQ6kkJg
I had ordered a Braze Technologies Space Invaders Multigame from arcadeshop.com, and I installed it in the hopes that it would help me figure out what the problem was. When it started up, the selftest showed 'Bit: Fail'. I had no idea what this meant, and I wasn't able to find any information on it on the Braze or Arcade Shop sites. However, I found this thread, which led me to checking the 4241 chip which apparently is a bit shifter. After I took it out of the socket, I found that the legs of the chip were pretty corroded. I cleaned them as well the edge connector again, and that seems to have solved my problems!
Thanks again for all of the information!
Rich
