Zinfer
More of interest than searching for a fix. Is it common for the lights to dim with the thump-thump audio? The lights seem to keep pace with the beat. Just curious if that's a pretty common experience.
This should not be happening. The lights are their own speparate circuit. My guess....the lights/light sockets are dirty or getting loose. As the game "thumps", it cause minor vibration....causing the issue you're seeing.
These things work great for cleaning out the socket...
http://www.marcospecialties.com/product.asp?ic=77-SCS
Also, hit the sides and base of the bulb with some sandpaper
Edward
Mine doesn't
Mine does the same thing, its definately a power issue. However game works fine so im not messing with it untill it gets worse or stops working all togther. on a sidenote my volums is cranked up so if i turned it down, i bet it wouldnt be as noticable.
