learpilot2 Member Joined Jul 12, 2009 Messages 167 Reaction score 0 Location HILTON HEAD ISLAND, South Carolina Feb 20, 2010 #1 I saw on the forum that SI marqee bulds are 1895. Can I use N47 instead. What is the difference between the two? The burned out ones I pulled out were N44. I guess the last owner had the wrong ones in.
KenLayton In Memoriam Joined Dec 14, 2003 Messages 20,220 Reaction score 712 Location Olympia, Washington Feb 20, 2010 #2 # 1895 bulbs are the correct ones to use. They are 12 volt and available at any auto parts store. 44's and 47's are 6 volt and should NOT be used.
ArcRevival Well-known member VAPS Joined Aug 31, 2006 Messages 10,147 Reaction score 1,099 Location RAPID CITY, South Dakota Feb 21, 2010 #3 You can also use a 14 volt bulb, it wont get near as hot and crack the paint on your bezel but it will still be bright enough.
