Since we're dealing with digital electronics, you dont necessarily need to be concerned with voltages since most signals are either on (5v), off (0v) or pulsing (changing state). For that chip all you need to be concerned with is pulsing. If one output is not pulsing, THEN you figure out why. That last board i fixed, pin 15 was not pulsing because the input was stuck high on the chip generating it.
As far as knowing what to look for..you need the datasheet of the part in question. It helps to have a comp with internet access nearby.
What your describing almost sounds like what i was seeing while trying to figure out the rom mod, but im not sure where id start.
