Space Invaders Deluxe Issues
Phetishboy
Avon, Minnesota
Bought an SI Deluxe at auction last week. It was on dead row and was not plugged in during the auction to see if it would even power up. I got it home, messed with it, cleaned up the outside and plugged it in. Good news, I got a loud humming sound and the monitor came to life. Bad news is all I see is a rug pattern. The inside of the game smells pretty moldy, so I am sure there is some corrosion and moisture damage. Where do I start and is anyone fixing these boardsets anymore?
i'm not going to be a ton of help on this, but i'd start by checking voltages (http://elektronforge.com/TestMdwPS.htm) and then checking for cold solder joints on the pins for the connector on the p/s.
when i got my space invaders i had a missing saucer sound as well as a random boot to rug pattern, and reflowing the solder on the p/s fixed that.
Replace the rom sockets and CPU socket...make sure slam switch isn't stuck closed, make sure all voltages are spot on including the reset line. Clean up the 2 fuses in the power brick.
Get board working without roms (bars on screen) before anything else.
