Space Invaders Deluxe help
Pharmtech78
Florida
Guys i bought a non working SID and i need to replace all the rom chips (D-H). All of them have broken legs. Also i have a SI board that i took the CPU from because the deluxe did not have a CPU on it. Would that CPU work on SID? And where can i buy the roms from to replace?
hobbyroms.com can burn you new roms.
Or you can add the SI multigame kit from Braze / HSS which replaces all the ROMs and provides better self-test. If in doubt, you can add a known-working 8080 processor to the order ->
https://www.highscoresaves.com/braz...ave-kit.html?options=cart&product_type=simple
>> compare the costs and the advantages/disadvantages of each option :)
Thanks for the info. I think i will go with the multi kit and add the CPU chip just in case. Hope it will work once installed :).
Be sure to check the power supply first (5VDC etc).
If the ROMs had bad pins, it's probable that random sockets are also bad. The multikit installs into the CPU socket - might want to check it's a good/clean socket.
If issues with the logic board, the multikit might help debug bad ram etc.
I think a good choice to go with the kit. A few more $$ but better overall solution.
Will do guys, thanks again. I did however purchased a switching power supply from arcadeshop to eliminate the old power supply.
Does anyone have info on the 2 fuses at the bottom of the cabinet? One of them i'm not getting continuity.
