Space Invaders Deluxe cabinet construction
Levis, Quebec, Canada
Hello guys, i'm planning to built a SID cabinet from scratch, any tip where i can get plans.
I already bought boards and benzel from ebay.
I can not find any machine nearby, i live in Quebec Canada, any suggestions?
Thank you!
Sorry for my english, i'm french Canadien.
Sylvain
are SIDs that scarce in canada you got to build one?
my stencils are cut in the shape of the cabinet
that will give you the sides at least. :D
but theres alot more to the interior design than meets the eye on that one.
art backdrop, mirror, etc.
Thank you Richard i was planning to buy your stensil set already.
I just received my pcb set on friday, first i start to fix it and next i will need a lot of close up pictures of the cabinets, inside and outside.
I will use your stensil for the size of the sides and my glas bezel for the front.
Will come back later with results, if anyone can give good pictures it will help.
Thank you guys, good to me people sharing same passion.
Sylvain
If you find somewhere to get the correct back drop for a space invaders deluxe, let me know. Mine is missing, the correct one is green I believe. I have the correct base, just need the correct back ground.
