tbullet
I decided to install the Multi Space Invaders board in my Midway machine. That went without problems. I did notice that the buttons were not as responsive to I decided to replace the leaf switches with new micro ones. Replaced all the connectors with new ones and soldered quick release ones for better access should I have to remove the switch.
System powers up ok, but at the INP section, it states error. Left and right as well as fire work on the menu, but player 1 and 2 do not respond. The values on the bottom of the screen show that the switches are working but I can not get the game to start any games. I checked the connectivity of the wiring, that seems sound, but however, I can not get the player 1 or 2 buttons to do anything. I tried manually coining up the game but that doesn't do anything either.
Suggestions on what to look for next? Checked where the control panel plugs into the connector to the motherboard, and that is fine.
Everything was working fine until I replaced the switches with new micro switches.
Thanks.
Thanks.
