Space Invaders Deluxe B&W Monitor Questions
Phetishboy
Avon, Minnesota
I thought I had a Motorola, but it looks like I have a WG 1001. Bob has a cap kit for a WG V1000. Same monitor? Same cap kit? Mine is working, but the chassis is filthy, old, moldy and stinky. The metal plate the chassis rests on is also as rusty as Marcia Cross's landing strip. I am also having trouble locating the focus pot. Could someone tell me where it is? I checked the flyback but didn't see it. I see a pot mounted perpendicular to the chassis but I don't wanna mess with that til I know what it does. Thanks.
The bob roberts cap kit you mentioned will work,i have done a v1001 and a v1002 with it.Not sure on the focus,maybe the unlabeled pot just below the flyback in line with the rest of the pots.
The cap kit replaces all the caps except the large "can cap" ,that has 3 or 4 caps inside of it.There is a thread on here with the values of the caps if you wanted to cap it as well.It took a little figuring with the schematics to get those replaced though.
Yes Bob's v1000 is the cap kit you want. It covers 19v1001-19v1003 and the 23" monitors 22v1001-22v1003. The focus is located near the flyback lying down against the PCB R271 I've included a image from the manual
