Space invader bezel lights question
pacman71
Iowa
Okay so I put a switcher in my space invaders. Got the backlighting in the cab up and going...
Now what is the trick to getting the bezel lights behind the glass to work properly?
I disconnected the 0 and 155 AC from the block?
Anyone have any experience with this one... please help out
Well, i would have kept the block hooked up, and just removed the power going from it to the board, since you're using a switcher.
I can't remember, but are they just little bulbs in a row? if so, just run a ground and +5 jumper from the switcher DC GND and +5 to the two wires to those lights. If the bulbs are too dim, move the wire from the +5 to the +12...
The original set up was a fused 12 volt tap straight off the transformer. As Mod stated....run juice from the switcher to the loom....add appropriate size bulbs.
Edward
