Probably going to have to put up a video or audio recording.
You can determine which sound board might be causing the issue by removing the audio connector from the soundboard first, then try the same test but with the speech board, however you'll need to jumper the speech board connector to get any audio.
Once you know if a specific board is causing the issue we can go from there.
