luke9511
was wondering what you all think i could get for my space duel, i dont have any pictures right now but will have some soon, but here it goes
the side art is in great shape except for some small dings and scratches
the marquee is in great shape
the monitor has been capped and everything, however the brightness is turned down as low as possible cause if you turn it up more than what its set too you will get lines on the screen that completely mess up the picture,
there is also a phosphor burn on the screen in the form of a good sized dot right in the middle, it also has some tempest burnin so im guess this monitor was in a tempest when it went bad and someone took the space duel monitor for the tempest
both coin mechs work though the coin doors need new locks and will need to be sanded and painted
the CP needs a new CPO which i have and will probably install before i sell it, it may need new buttons but i will leave that to whoever gets it next
im currently rebuilding and sanding/painting the power supply to make it new again
i have cleaned out and vacuumed the inside of the cab so it looks atleast a little bit clean
there is some swelling in the cab which can be seen by the piece of wood just above where the back door goes so that will need to be replace and there is no back door so it will need one of those aswell,
the bottom edge of the cab is crumbling so that will need to be addressed
if i think of or see anything else i will post it, if anyone has any questions feel free to ask them here, thanks for looking and thanks for helping get this thing working again
