Rat
Have only had my SD cocktail a short time and mostly it's OK but I would like to have it perfect.
The issue is the green vectors flicker on and off. Seems to possibly be slightly more stable after its been on awhile, but will still happen occasionally.
The seller put a new caps kit throughout so it's not that.
I'm thinking it's loose wiring, I have reseated all the plugs. At one stage I did find a green wire going to a plug that made the worse, green disappeared if moved about. I have reseated and checked that, but I had trouble getting the plug out of the metal holder on the side of the cab, so I have not been able to re-solder that yet. Not sure that would help as it looks fine.
So should I persist with trying to remove this plug risking breaking the brittle plastic, or check other things?
Perhaps there is a voltage pot I could adjust or something?
I'm a noob with my multimeter but if you hold my hand and show me pictures I will have a try
I have downloaded the manual and had a quick read, but now I'm at work using my phone for a few days. So I can't take pics of the plug ATM. Just hoping for a quick head start on my trouble shooting when I get home. Any help greatly appreciated.
