Space Duel Cocktail MultiVector
Black Widow and Gravitar are the same hardware...
It's not too much work to make Space Duel run on BW/Grav.
I did a little work on 3-1 add-on card a long time ago, but Now I have at least 2 of each game, and space to keep them all, so I lost my motivation to work on it.
Tempest is vertical, but I guess the control scheme works with the monitor on it's side though. :)
Swap X and Y outputs, adjust pots on board to shrink the image down to fit on a horizontally-mounted monitor. Back in my old multigame cabinet (nothing fancy, just brute-force swapping of harnesses via long adaptors to the bank of boards), both Tempest and Quantum worked just fine. With Quantum, I also had to swap the X/Y trackball controls.
Were you doing that on an Ampliphone? Not sure I would like the resolution lost to the shrink on a 6100. Someone on here (2048 I believe) was selling A Gravitar cabinet and showed Tempest in play in the pics, but I couldn't tell from the pics if I should be concerned....
I was hoping it would have been possible to incorporate Major Havoc with the use of the Space Duel adapter board. This way you could use the spinner on the multi-vector control panel. Either way, a cool way to get 3 vectors in the space of one cabinet. Very cool stuff indeed.
Maybe this thread is long gone.. I was wondering if you'd be willing to sell the plans so I could build my own? that is unless you sell this kit.. which I haven't seen anywhere.
Troy
Troy
I will be releasing a updated version of the kit very soon :)
Mike
Vector Labs
Any E.T.A. on when this will be in the works? I'm very interested. Should I start looking for Space Duel & Gravitar PCBs?
Tempest looks and plays fine on a horizontal monitor:
