Space Ace/DL Volume pots?
Anyone know off hand what kind they are?
Here's a link to my web page.
http://members.cox.net/samsarcade/Dragons_Lair_volume_control_diagram_page.html
Dragons Lair and Space Ace use 2 - 10K Audio Linear pots.
attachment.php
Not to disagree, but are audio pot's not logarithmic as opposed to linear?
Any any regards, the OP can try Digikey as they carry both kinds.
Normally you are correct, Volume controls are logarithmic or audio Taper but for some reason here they use a Linear Taper pot.
It might be hard to see in the picture but the part number is RV4NAY SD 103A
Yes it is Linear not Audio Taper. Most volume controls are Audio Taper. Either should work, just might make the volume range of the knob a little different but if you want the correct one then that's the number you need.
http://search.digikey.com/scripts/D...rs&WT.srch=1&WT.content=text&WT.source=google
